Rough Country 2.5" BB problems
Old 06-11-2008 | 02:00 PM
07WrangX's Avatar
Originally Posted by bly109
With 2.5 BB, I only needed to center the steering wheel, no alignment needed. It drove straight, handled fine, and tires wore perfectly for the 10K I had it on for. Besides, the only adjustments that can be done by an alignment shop to a stock JK with only a BB are centering the steering wheel and Toe-in.
And my stock steering stabilizer is still fine. I even ran our JK without it, just to see how everything felt and I didnt even have a shimmy.
I called RC after installing mine and they told me that it would need alignment. I noticed a big difference after doing so. As far as the stabilizer, I felt my steering getting a little bumpy so I put one on today and immediatly noticed the difference. Especially on the highway!! My steering is a lot tighter now.
Beta-pg's Avatar
I have the RC 2.5"... 33's and NO issues! I didn't even have to recenter the steering wheel. Everything went on great in a couple of hours and is tight. Sweet ride. I have the shock extensions as well...
Old 06-11-2008 | 02:02 PM
theosdad's Avatar
That makes me feel alot better
Old 06-11-2008 | 02:07 PM
Mark Doiron's Avatar
Veteran: Air ForceFJOTM Winner
I put on the RC 2.5 with the 2.2 shocks. I run 33s. It tends to wander more, which is "interesting" when it's windy out (which it always is in Oklahoma). However, it was not unacceptable. As for aligning: What's to align? You can adjust toe-in and recenter the wheel yourself (mine needed the latter). If you'd like tighter steering, you'll need some more hardware. Plenty of other threads on this forum offer confusing and conflicting opinions on exactly what, so I won't contribute to that noise. I say take the vehicle for a drive yourself and see how it feels.
Old 06-11-2008 | 02:20 PM
theosdad's Avatar
Can I use the install instructions that wayolife has for the teraflex to install the Rough Country. I figure it should be the same?
Old 06-11-2008 | 05:21 PM
Big D2's Avatar
Yes, you can.
Save your money. You don't need an alignement. Unless that it will make you feel better, and then you'll have someone to bitch at when it still wonders.
For alignement, all you can do is recentre the wheel, and change the tow if you want. You could do both yourself, or if you really want to pay someone then go for it.
Check to make sure everything is tight.
LOWER YOUR TIRE PRESSURES!!!!!!
Sorry, but I can almost tell you tires are above 33psi or more. Drop them down to 26lbs and see how it drives.
Next, fill up your Jeep with gas. I know it's expensive but don't be a cheap skate and put some gas in it. The extra weight will bring the rear down a little. It's what makes it wonder a little.
Lastly, make sure the wheels are balances. Soft 8's have had some issues of being out of balance or hard to balance. The fact that it has a different offset than stock doesn't help either.
Hope this helps.
Old 06-11-2008 | 07:30 PM
bly109's Avatar
The "wander" is from the axles being off-centered. Mine stopped the slight "wander" after I added the front adj trackbar. But like you said, it was no where near unacceptable.
Old 06-11-2008 | 09:22 PM
Kiernan's Avatar
I just had the RC 2.5" installed a few days ago. I had it done by a local shop and had them align it. So far, no issues at all. I also got the 2.2 shocks. I'm riding 33's with soft 8's.
Old 06-11-2008 | 10:10 PM
jeep4life's Avatar
how easy is the install? Are there any writeups?
Old 06-12-2008 | 03:49 AM
judesign's Avatar
You could teach a monkey to install this kit. Theres a great rightup with pics here somewhere. just search 'rough country install' for the title.
Quick Reply: Rough Country 2.5" BB problems
