Rough Country 1.25 BL
Anyone got any pictures of 2.5 coil lift with 1.25 BL...I am planning to go 37 with flat fenders...Already have TF Coil planning on adding 1.25 RC BL...
Note that there is a ground strap that goes from the passenger side engine block up to the fire wall that when you jack up the body to install the body lift, you may rip the cable out of the loop terminal. Mine did get pulled out. It pulled out of the firewall side loop terminal, so I removed the entire thing, re-crimped it and soldered the braided wire into the loop terminals on both ends. The cable is long enough for a 1.25" body lift with slight slack, but no more than 1.25" would work. The loop terminal on the firewall is just to the passenger side of center, about 4 inches down. You can't miss it. After you install the body lift, go verify this is still intact, or remove that top bolt during the install and replace it after.
I ran the same set up when I moved to 37s for over a year with no issues. Do you have an auto or manual. If manual you will need to make other modifications
