Rough counrty 2.5" spacer lift?
Hey guys anyone have this kit? How do u like it and can u post pics? Also did u add anything else to the kit?
http://www.roughcountry.com/jeep_jk_2.html
[ATTACH]20650
I was running this until yesturday. It is sitting in my garage. I was able to pick up a mopar coil lift from a friend so I made the switch. I would have kept running it if I did not get a good deal on the new lift. So go for it..
AMen
Here is a pic
AMen
Here is a pic
Originally Posted by AMen
20650
AMen
Here is a pic
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=206501"/>
AMen
Here is a pic
KM2s 35" x 12.5 on set of ProComp, this lift is good for a budget, and when you get more money you can change it out and sell it.
AMen
2.5" lift
I had one on my '09 for a month then switched to the R.C. 2.5 coil lift which rides softer not sure if I like that or not. I run 305 70 17's (34" diameter), with 17 x 9 rims, Jeep is great to drive, however I do see the value in adding a dropped pitman arm to contol the bump steer and some method of regaining the caster in the front end, as it now requires more attention while driving...
Last edited by mkjeep; 09-04-2011 at 11:27 PM. Reason: no selling your parts till you reach 50 posts, read FAQ
