Rotated tires = DW
I'd be willing to bet that it is his stability control kicking in and not "death wobble". Betting also that the rotor retaining clips are still installed and those 20" 35's are way out of balance. Coupled with an off-center steering wheel it's a recipe for SC to kick in.
Factory wheels are relieved on the reverse to account for them. Aftermarket wheels are not. It causes the wheels to not seat correctly at the hub, and eventually come loose. They might appear to be mounted tight but do not remain so for very long. It'd be worth checking.
This can definitely happen. I had the same issue with a set of tires. As soon as I rotated them the death wobble went away. And yes I know what death wobble is before anyone says oh it's prolly something else. At a certain speed it would shimmy a little but if I hit a small pot hole or bump or something like that, full on death wobble. I later changed those tires out and then didn't have an issue from then on out for sure.
Ok. I took off the front wheels and there are no rotor retainers. I reinstalled them and just for giggles raises my tp from 30 to 35psi. The violent wobble went away but the is still a slight shimmy. I'm guessing it was magic. But I still think I've got a wheel balance issue that showed up.
Get them balanced. Same thing happened to me recently after a tire rotation. Tire shop said one of the front tires was out of balance. It wasn't a problem when that tire was on the rear axle.
The fresh balance took care of the problem. I also took a torque wrench to the front axle and steering linkage.
