Roof rack options for hard top
I don't see the big deal, you have to drill your roof with all of them, its just the way they line up that's different. the others will decrease you milage because of wind resistance were as the NEBO will not as its just two rails going lengthwise. No wind noise, or anything when not using cross bars. and 1/2 the cost of the rest as well.
I was looking at going with the rhino rack, but there would be 6 stupid little pads always on my roof when the platform was off. I didn't want to keep the platform on all the time since it would reduce range when not needed and wind noise would be greater. I never wanted the MBRP, as I don't like the huge bars hanging down the sides of my jeep. Just not attractive to me. The teraflex fit the bill when not using platforms, racks for bikes or kayaks its as quiet as my factory patriot rack, no exta wind resistance, and just looks great on the roof. once installed the rack can be used to suspend the hard top from for storage. put the two freedom panels inside the rail and hook on to the rack, and up she goes for softtop weather.
I don't see the big deal, you have to drill your roof with all of them, its just the way they line up that's different. the others will decrease you milage because of wind resistance were as the NEBO will not as its just two rails going lengthwise. No wind noise, or anything when not using cross bars. and 1/2 the cost of the rest as well. I was looking at going with the rhino rack, but there would be 6 stupid little pads always on my roof when the platform was off. I didn't want to keep the platform on all the time since it would reduce range when not needed and wind noise would be greater. I never wanted the MBRP, as I don't like the huge bars hanging down the sides of my jeep. Just not attractive to me. The teraflex fit the bill when not using platforms, racks for bikes or kayaks its as quiet as my factory patriot rack, no exta wind resistance, and just looks great on the roof. once installed the rack can be used to suspend the hard top from for storage. put the two freedom panels inside the rail and hook on to the rack, and up she goes for softtop weather.
Range is important with us, we do a lot of long distance runs with no pit stops in between. The Teraflex can take 850lbs static and 215 active load. That's enough for a roof top tent, and 2 people no problem. what more would you put there?
I started with the HD Whispbar gutter mount racks. I wasn't happy with the way they clamped to the gutters on the removable panels. In December I installed the Yakima track system and changed out the mounting feet on my Whispbars. Pretty easy to remove the racks and the tracks are discrete.
I have the MBRP rack, with basket, front extension and with mods to accommodate an AEV snorkel and a second spare tire. This is on a 2007. If you just have the basic rack--no extension or basket--then your swapping of the top will be fairly easy. But, it's a heavy rack. When I swap mine (with the basket, without the extension which is removed separately), then it takes four people to handle the top. It's not really any extra time than removal without the rack, just extra people. Removing the extension and mods is a half hour, but you may not need any of them. If you have a winch to remove the top in your garage, then it will be easy. Probably even easier, since the MBRP rack can be used to pull the top off. I have a rack to store the top in the garage standing up (takes up less space), but with the rack it tends to want to roll over backwards--not good. I crushed one of the wheels on that rack, so I've ended up using blocks of wood to keep it upright.
My biggest complaint about the rack is the quality of the powdercoat. It's horrible. It is so thin that it has started flaking off in places. Yes, I've had it for a few years, but I've had my Shrockworks bumpers and rock rails for even longer, and they show no hints of rust through the powdercoat. But, they are black semigloss powdercoat, not krinkle finish. I was told the krinkle finish is typically thinner and not as durable, and I'm here to attest that has been my experience. With the MBRP rack, however, you get no choice for finish.
Other than that, I really like the rack. It's practical and can carry a huge load. As for wind noise, I really didn't notice any until I added the extension and moved the overhead lights up above the windshield. With that, I notice wind noise only when it's windy, I'm driving into it, at highway speeds. Other times I really don't notice it. But I don't expect Cadillac-quiet in my Jeep, either.
With mod for AEV snorkel, and mod to carry second spare partly complete (now I don't need to use a cargo strap to secure the tire--I have a screw plate that centers the tire and holds it down).
Just the basic rack and basket ...
