roll cage - custom weld or bolt in?
Old 01-05-2014, 12:46 PM
  #21
Murder¹'s Avatar
Also when getting a custom cage put in the more prep work you do before hand the less the shop has to do(remove carpet, seats, drill the hole in the dash) so you can cut down on costs there.
Old 01-05-2014, 12:47 PM
  #22
jeepwave's Avatar
I absolutely agree with you but I think there is a general starting point.
And I know that I can save money and still be safe but I can also save money and not be safe. My point is, is a bolt in cage going to be sufficient? Or is a weld in cage necessary ?
Old 01-05-2014, 12:51 PM
  #23
jeepwave's Avatar
Good point, already don't have carpet so that's a plus hahahaha
Old 01-05-2014, 01:02 PM
  #24
Joe_B's Avatar
This guy had a bolt in cage and they both walked...they do the job.
The initial roll:
http://www.youtube.com/watch?v=aRlHXfoitUA"]http://www.youtube.com/watch?v=aRlHXfoitUA Start it at 1:30 and you'll see the cage did it's job
http://www.youtube.com/watch?v=1WM9vF096Jg"]http://www.youtube.com/watch?v=1WM9vF096Jg
Old 01-05-2014, 01:58 PM
  #25
jeepwave's Avatar
Some proof I was looking for thanks. That's crazy. Everything does look in tact as far as the cage goes
Old 01-05-2014, 02:08 PM
  #26
rsbmg's Avatar
The initial roll:
That should buff out.
Old 01-05-2014, 02:12 PM
  #27
ABENDX's Avatar
What do they say about a woman with two black eyes?
Old 01-05-2014, 02:17 PM
  #28
robsjeep9's Avatar
Ask the OP she's a female
Old 01-05-2014, 02:41 PM
  #29
tcdawg's Avatar
Still wondering though if I weld the poly performance isn't it just the same as a bolt in? The mounts are bolted anyways? Or is it that it's welded to my existing cage as opposed to Bolted like the others? I also heard that genright is coming up with a cage for the jk. Does anyone know what price I would be looking at for a custom weld in cage ?
The Synergy cage is welded to to your existing cage. It adds cross bracing at the upper and lower windshield and harness bars behind the front and back seats. It adds A pillar and B pillar supports that bolt to the bottom of the tub, directly underneath the tub in these locations is a welded frame mount. The frame mount is bolted through the tub to the A and B Pillar supports. There is so a C pillar support, it is bolted to the tub w no frame mount. It also adds stringer bars from the upper windshield bar to the center console and then to the existing upper rear bar.
Custom cages would most likely start at $3000 and go up from there, depending on what you wanted and of you wanted them to work with OEM soft or hard tops. At least, that is what I found
Old 01-05-2014, 02:47 PM
  #30
jeepwave's Avatar
Originally Posted by tcdawg
The Synergy cage is welded to to your existing cage. It adds cross bracing at the upper and lower windshield and harness bars behind the front and back seats. It adds A pillar and B pillar supports that bolt to the bottom of the tub, directly underneath the tub in these locations is a welded frame mount. The frame mount is bolted through the tub to the A and B Pillar supports. There is so a C pillar support, it is bolted to the tub w no frame mount. It also adds stringer bars from the upper windshield bar to the center console and then to the existing upper rear bar. Custom cages would most likely start at $3000 and go up from there, depending on what you wanted and of you wanted them to work with OEM soft or hard tops. At least, that is what I found
Really does sound like the poly perf. Cage does exactly what I need it to do.
Quick Reply: roll cage - custom weld or bolt in?
