RockKrawler3.5 max travel install question, relocate rear sway
Mine was barely touching so it would rattle at idle. I have a '12 i don't know if your exhaust setup is the same but I loosened the exhaust clamp on top of the axle and pull the muffler back a little bit then tightened the clamp
and it worked until it landed on a boulder so I went with the dynomax rock crawler exhaust. If you don't move the sway bar back the sway bar links will hit the the back side of the lower control arm on the axle.
