rockhard skids or interior front cage?
Former Member
1 Post
I'd like to do a interior cage for the front of the jk but I'd like some more protection underneath.
We do run trails that are nasty rocks and rolling over is always a possability but so is trashing everything underneath.
It is either the interior or a full underneath kit, which would you do first.
I'm pretty open either way but what seems to make the most sense, I have my opinions but input would be nice.
I feel skids would be better first so you don't destroy everything underneath. Your more likely to need your skids on a daily bases. My skids are trashed from constant use but beefing up my cage is definitely on the list
Former Member
1 Post
Yeah my stock skids are hammered but still going. I then consider that my stockers will hold for a bit more and if I flip the cage would be nice. The skids would definently be a every time use the cage would probably be a never or 1 time in years use....skids and cage scan save a hit that's a game over for the day so they both are pretty important.
Originally Posted by r3cluse
I'd say it depends on which side you plan on facing down more often.
Factory skids are more than sufficient. If anything, a simple oil pan skid like the Rancho which slides over the stock engine pan will protect those vitals. The aftermarket full underbody systems have proven to be unnecessary. Systems like the Rockhard and River Raider are difficult to remove on the trail in the event of needed repairs between the skid and underside of the jeep. They can trap more heat than is needed under there too.
The sport cage is always a plus if you wheel hard enough to think you may flop at some point. It does add some needed protection and will stiffen the body which can see a good bit of flexing over time on rough trails.
In the video link below, all of our jeeps are running the factory skids and a version of an oil pan skid and that's it.
http://project-jk.com/jeep-jk-videos...run-highlights
Former Member
1 Post
Would be slow and more than likely large rocks, more than likely side landing.
Plan is to do both eventually....
