Rock slider recommendations
Old 12-04-2020, 07:42 AM
Just4starters's Avatar
Originally Posted by jadmt
what are you going to do with your rig? just drive around or hard core offload? If offloading look at some LoD sliders.
as a beginner,,, I’m going to go trailing then learn from there. But the 4.5 lift & oversized tires. A Challenge to get in.
Originally Posted by Mike H.
Good thread/discussion/experience-shared on frame vs body mount here.
https://www.jk-forum.com/forums/modi...-341112/page4/
thanks for help
Old 12-04-2020, 07:45 AM
Originally Posted by ballistik_monkey
x2 on LoD. frame mounted, bolt on. as far as fit, finish, and quality...tough to beat. you may not like them due to having a small-ish step. but like others have said: are you offroading?...or just want more of an actual STEP. if you are looking only for a step as said: get which one looks the best to you and rock on.
Needing a means of gettin into the rig but don’t want them to protrude outward so much.
Old 12-04-2020, 12:20 PM
hornetman's Avatar
My ACE sliders were relatively inexpensive but have a great powder coat whereas I’ve seen some buy the cheaper ones that start rusting immediately. Again No rust on my ACE and easy mount to the frame.
Just4starters (12-04-2020)
Quick Reply: Rock slider recommendations
