rock krawler heavy duty tie rod setup
Old 10-13-2008, 08:13 AM
Originally Posted by tgrt
Is the diameter the same? The bracket for my Superlift steering stabilizer probably wouldn't fit anything bigger.
its definitely bigger then the stock tie rod
the superlift steering stabilizer bracket works just fine, just needs to be ground down a bit to fit the larger diameter tie rod
that the setup im running and its great
Old 10-13-2008, 08:15 AM
Frog Rubicon's Avatar
Be careful with the tie rod, a bad installation can be dangerous
Old 10-13-2008, 09:52 AM
robin's Avatar
I'd like to see this too
Old 10-13-2008, 09:55 AM
Former Vendor
tgrt's Avatar
Thanks exactly what I needed to know.
Old 10-13-2008, 10:08 AM
greasemonkey85's Avatar
here is the best picture i have now, but it took its abuse over the weekend!
Old 10-13-2008, 10:15 AM
Eternal ***erator
HappyCurmudgeon's Avatar
There are pictures of it installed here from Offroad Expo.
More Here. Click me:
Old 10-13-2008, 04:25 PM
walker's Avatar
I like that! I must add it to the list!
Old 10-13-2008, 04:27 PM
how did they flip the drag link rod end over on the passenger side knuckle? can you drill it out and get some kind of tapered insert?
Old 10-14-2008, 01:19 AM
Eternal ***erator
If i manage to botch mine up, i will probably go this route, I havent seen these in person, but they have a description here: Heavy Duty Drag Link
The Rock Krawler heavy duty Drag Link for the Wrangler JK is simply the strongest drag link on the market! This bad boy is made from 1 1/2 inch diameter solid alloy treated steel and is machined to accept 3/4 ton outer tie rod ends. The Rock Krawler drag link is a plug and play upgrade with no drilling or having to change the taper of the factory knuckles. The drag link assembly has turn buckle style adjustment with wrench flats for precise centering of the steeing wheel which is crutial for ESP compatibility!
Old 10-14-2008, 04:32 AM
freshjk's Avatar
I have been waiting for a heavy duty setup!! A must have.....
Quick Reply: rock krawler heavy duty tie rod setup
