Rock Krawler Grease Fittings?
I am in the process of installing a 2.5" Rock Krawler X-Factor lift. The loft instructions say that the spherical joints have extremely close tolerances and do not need grease, just WD-40, and do not come with grease fittings.
However, the box that the springs came in, had a plastic envelope containing some instructions (for the Stock Mod) and two grease fittings.
Are these fittings actually used, perhaps on the track bar?
And my x-factor came with about 13-15 fittings. If you only had a couple then something is wrong.
The spherical joints that have the zip tie holding them together are the only ones that don't need to be greased. Just hose them down with the WD-40. But all the other ends that have a hole for the zerk fitting you will insert those after you set the jam nuts.
I'll have to call RK today just to be sure. The instructions clearly state that the threaded hole does not need a grease fitting. Which joint do they consider a Flex Joint?
MAINTAINING JOINTS
KRAWLER JOINTS (Rebuildable spherical joints):
HEIM JOINTS (Non- rebuildable spherical joints)
MAINTAINING JOINTS
- Depending on use and climate, every 3-5 years is a good time to take apart the joints, replace the raceways, and re-grease and clean the internals.
- Spray down the outside of our joints liberally with WD-40 or similar lubricant.
- Any additional information specific to a certain generation of Krawler Joints can be found on our website. (Rockkrawler.com)
- Heim joints also benefit from spraying down the outside of them liberally with WD-40 or similar lubricant.
- Our Flex Joints (bushing end) will benefit from being greased routinely. If there is no grease fitting, spray the exterior of the joint with WD-40 or similar lubricant.
I remember reading the same thing, and having the same questions. I did find other threads that said to use the fittings where you can. For me, as many creeks as I cross I didn't want to take any chance of getting water/mud in the holes.
Former Vendor
RK
You don't need anything on those nipples going in and they don't require much torque at all. If you go after it with a 3/8" ratchet, you will break it.
Thread them in and do easy turns until they stop- you're all set. I'm in Chesapeake if you have other install questions, just did a 3.5" x factor.
