Rock Krawler 3.5" lift?
ok as always i'm looking at lift's. so the new lift is the 3.5" rock Krawler entry level lift? what is needed with this lift to ride safely. all i plan on running is 33's.
i just want to know if i need drive shafts as well as anything else. please anyone help me out! i found it for under 500.00 shipped.
Yea
yea i kinda was thinking the same thing. Drive shaft will be a must. what about control arms? what shocks would do good with this. i know i cant use the stockers. or can i?
you ever look at the tera 2.5" coil kit? you can run your driveshafts and it gives 3" front and 2" rear. That gives a nice level ride and can fit 35s. It is only like $680 with shocks.
yea
yea that is the original kit that i've been looking at. but i also plan on eveutally going to long arm. and the RK kits are build able. still not to sure. still looking to see what i'm going to do.
oh if you are gonna go long arm, you are gonna need driveshafts no matter what. I thought that was a primary concern.
I lost my front driveshaft boot 5 minutes into the first trail after lifting my jeep. If I was you I would plan on at least a front shaft and like he said a pair of front control arms to correct caster. You might should get a set of rear uppers to correct pinion angle as well. 3.5" is quite a bit of lift.
Yea that's
