Rock Krawler 2 Door Specific
#21
My rear 2.5 RK coils were bowed to the point I was lower in the rear than the front. I added correction wedges and they are closer to straight and I am now even front and rear. Any additional length added to the lower control arms would bow the coils worse.
#23
It could be the weight of a steel bumper, carrier and 35 hanging off the back. There are also differences in older vs newer RK coils and differences based on 2 dr vs 4 dr coils.
#25
I have a heavy rear bumper with a 37 on a steel tire carrier and a pretty heavy steel front bumper with a warn winch and steel line. I'm running no backseat. I recently removed the tire on the back and the height stayed the same.
#26
#28
Fwiw my rear 2.5's are first run. There was a change along the way. If you look at mine and the new coils. Mine stack up on the top whereas the new coils dont. The newer rear coils are softer from what i was told .. Better ride but comes at a expense .. Sagging.
If somebody is not having sagging issues running heavy they prob have the old coils.
#29
Lol and on request. jadmt is now running 3.5's in the rear due to sagging. Fwiw my rear 2.5's are first run. There was a change along the way. If you look at mine and the new coils. Mine stack up on the top whereas the new coils dont. The newer rear coils are softer from what i was told .. Better ride but comes at a expense .. Sagging. If somebody is not having sagging issues running heavy they prob have the old coils.
#30
