Rock Krawler 2.5 stock mod actual lift height vs Teraflex 2.5
Old 02-24-2016, 06:44 PM
  #51
karls10jk's Avatar
Full flex- the shock body will contact the frame and your spotter will see the shock bow out. One day it'll give up the ghost and snap the shaft. There are a few documented cases of the 5100's doing this and I've seen first-hand the fox do the same thing.
I've got a 4dr with the 3.5" x factor and fox shocks in the driveway. I have the 2.5" stock mod with Rancho. I've not had a chance to see if mine will bow the shocks, but I imagine it will.
Your alternative is to get limiting straps that stop the travel before you get to that point, but then you lose travel so that is counter-productive.
Old 02-24-2016, 07:02 PM
  #52
tvan93's Avatar
Full flex- the shock body will contact the frame and your spotter will see the shock bow out. One day it'll give up the ghost and snap the shaft. There are a few documented cases of the 5100's doing this and I've seen first-hand the fox do the same thing. I've got a 4dr with the 3.5" x factor and fox shocks in the driveway. I have the 2.5" stock mod with Rancho. I've not had a chance to see if mine will bow the shocks, but I imagine it will. Your alternative is to get limiting straps that stop the travel before you get to that point, but then you lose travel so that is counter-productive.
And this is only on the front? Relocation doesn't cost much so I'll have to consider this at some point before I go full flex
Old 02-24-2016, 07:07 PM
  #53
Chuck-The-Ripper's Avatar
That's everywhere I've cut. I'm running no bump all around and have no contact anywhere. I am going to add 1" to the back just for safe measure though.
ID:	638762   Click image for larger version
ID:	638764   Click image for larger version
Old 02-24-2016, 07:12 PM
  #54
burton50x's Avatar
Originally Posted by Rock Krawler Suspension
We have had a lot of luck with 37's with 2.5" of lift. Attached is a vehicle with that combo: Coil sag has largely been eliminated. Coil Rate transitions were modified to ensure proper ride height. Typically if we see an issue with squatting it can be explained with pinion. That angle is explained in the directions and often overlooked when installing. That angle directly effects coil bow/loss of effective rate. We recommend our rear pinion angle to placed at 2 degrees below the output on the transfer case. Not doing this will cause interference with components and potentially sag the rear suspension. Rk
Wow that rig has about the same clearance between tires/fenders with the same 2.5 lift vs. my 35's.... Click image for larger version
Old 02-24-2016, 07:35 PM
  #55
tvan93's Avatar
Originally Posted by burton50x
Wow that rig has about the same clearance between tires/fenders with the same 2.5 lift vs. my 35's.... <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=638766"/>
Yeah. Shocking clearance...how do you like you're fenders? Been looking at those.
Old 02-24-2016, 08:07 PM
  #56
burton50x's Avatar
great price and have been holding up very well so far. Just FYI they are very narrow so the tires kick up everything.
Old 02-25-2016, 09:10 AM
  #57
Former Vendor
Rock Krawler Suspension's Avatar
This is a great suggestion especially if someone is running a larger diameter shock. This happens frequently with incorrect track bar length. If the track bar is too short, too long, and the axle is pushed to one side or another it increases chance for contact. However, if you're set correctly it reduces or even can eliminate the chances of the shock hitting the frame.
RK
Old 02-25-2016, 06:34 PM
  #58
m4belisle's Avatar
I gained this much:
https://photos.google.com/photo/AF1Q...-Rt5AKsPaoJcqF
https://photos.google.com/photo/AF1Q...MHUVp_HR2FuOMN
it's roughly 5" higher than a stock jk........about 2" from the tires and roughly 3" from the lift
Old 02-26-2016, 04:22 AM
  #59
tvan93's Avatar
Originally Posted by m4belisle
I gained this much: https://photos.google.com/photo/AF1Q...-Rt5AKsPaoJcqF https://photos.google.com/photo/AF1Q...MHUVp_HR2FuOMN it's roughly 5" higher than a stock jk........about 2" from the tires and roughly 3" from the lift
I couldn't see the pictures but those numbers are just what I'm hoping for.
Old 02-26-2016, 04:02 PM
  #60
m4belisle's Avatar
sorry, not sure why my photos aren't visible.....how about this?
https://im1.shutterfly.com/media/47a...D550/ry%3D400/
Quick Reply: Rock Krawler 2.5 stock mod actual lift height vs Teraflex 2.5
