Rock Krawler 2.5 stock mod
I would highly recommend the rock crawler springs. With the dual rate springs it rides better then it did stock.
I would contact Northridge4x4, I got a complete stock mod 2.5 kit with bilstein 5100 shocks, rear coil correction wedges, bump stops and spring clips front and rear for under 800. It was a complete kit ready to go. Only thing I bought seperation were brake line drop brackets.
I do like the dual rate springs they offer.
But it's your rig and your money.....gotta' do what suits you best, man.
I bought the 1.5" Max Travel kit for my 09 JKU from Northridge. It had 80K miles on it so I figured the LCAs and TB bushings were getting worn and could be replaced anyway. The LCAs and TB are really beefy. I like the ride but feel the 5100 shocks may be a little firm.
As everyone had mentioned lower control arms, bumpstops, and shocks are all recommended. This kit was designed initially as a fix kit for someone who already had a lift on their vehicle with some sort of caster correction and wanted an improved spring. If not a Flex system is a great option. It will include the front lower control arms for caster corrections.
As some have said, Northridge 4x4 is a great sales outlet for Canada. They have shock and bumpstop packages put together for your vehicle and our lift kits. Also, the majority of items are in stock and ready to ship.
Good luck with the lift and let us know if you have any further questions.
RK
