Rock Hard sliders (pics + experience requested)
I'm shopping around for some rock sliders, and I like the looks of the Rock Hard ones with diamond plate on top. Has anyone installed these that could offer a review and possible some pics? (only ones I can find are low res standard product shots...)
Also, I don't really like the look of the little black bolt caps -- can anyone tell me what's underneath them? Again, pics would be great... Thanks in advance
Won't help you if you really like the top flat portion, but if you're focus is more towards the boat-side style, Treks makes a nice set. Can't speak from 1st hand experience yet though.
Haven't had a chance to beat them up any, but I have no doubt they will hold up. Mounting was not too bad...did it by myself with a jack and jack stands. The step is nice for my wife and kids. It's not huge, but it gives them "something" to put their feet on. As for the mounting holes, they are attached to a small piece of rectangular tube. I added grip tape to the areas where you would step to help. If you pop the caps off the rectangular tube, beneath is the mounting holes, where the bolts attach to the body. As for leaving them off, would not be good. Alot of moisture and debris would collect in there. There is also a small gap between the small rectangle tube and body, where debris and moisture could collect. I used a gray silicone to fix this issue, even though it took a roll of tape and about an hour to get the caulk beads just right. I really like these sliders and have no regrets at all. I also did not mind drilling 22 holes in the body...some may. Mine are not diamond plate, but here's a couple pics to look at. Hope they help.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Perfect! This is exactly what I was looking for to help me decide. Still not 100% sure if I'll go for them, but thanks for the detailed writeup.
I have them and they are stout as all git out. I've beat them up in Moab with no issues whatsoever. They mount to the body and frame and I can't concieve of a stronger rocker guard. The only downside is that they are not cheap!
I have these as well and am very happy with them.
VERY STOUT.
I like the step on them as well, and the width of it keeps the side of my Jeep a little cleaner.
I need to caulk the space between the slider and the body of my Jeep.
VERY STOUT.
edit: you know what, I thought I was in the other thread still... long night at work
I'll assume they are the rock hards!
I also wasn't planning on changing my fenders and the RH fit nice and tight to the stock flares which would deflect mud nicely. After bumping a couple trees I've since got a set of River Raiders' fenders so that's a moot point for me now.
anyone know of a similar looking set of rock sliders that don't require drilling? i like the look of the rock hard and teraflex sliders, but they require you to drill into the body and i'm not really comfortable doing that.
