Rock hard cage powder vs paint and what color
Old 12-13-2015 | 05:16 AM
  #21
DaK's Avatar
DaK
WHOA WHOA WHOA... hopefully you get this before doing any ratchet strapping...
EMAIL the tech support and if their phone number is there CALL them... He will get back to you ASAP. Even on a Sunday. Believe they are a sponsor on this website, PM him your cell. He will call you and work this out. Probably some trick to the trade. He is on PST time so give him a few more hours to wake up and get some coffee.
Will admin the cage is a tight fit but its a fit none the same.
Old 12-13-2015 | 05:40 AM
  #22
SoK66's Avatar
Do yourself a huge favor and DO NOT try to install that cage using ratchet straps or the bolts for the horizontal dash bar. From your photos it's obvious the horizontal dash baryou have is simply too short. That is the issue I struggled with on mine. It helps to trim away the plastic end cap seating ridges on both sides of the dash so the horizontal bars' plates can sit inside the recess and not exert pressure on the dash when you tighten the dash bar bolts down. If you try to force the bars to fit it wil warp the dash and, as in my case, may bow the windshield frame. My dash has a permanent bow in the center, and I now find it is causing the defrost flaps to bind.
Good advice to call RH4x4 and ask for assistance. They shipped me a slightly longer dash bar that is still too short, but made it possible to at least get the product installed.
Old 12-13-2015 | 07:43 AM
  #23
Rock Hard 4x4's Avatar
Former Vendor
Originally Posted by Wrangeler X
Ok went yellow but now... The dash bar seems way too short!!!
Experiance..??? I think this dash bar is 1" too short!!
Anyone from Rockhard listening?
Northridge 4x4
Yep - we're listening! We're probably one of the most active sponsors on JKF - happy to help.
Couple things to check.
The angle you have on the driver side looks like it's orientated wrong, the collar doesn't look like it'd come down and grab the upright and seat properly. Flip the bar all the way over and see if that lines up better. Make sure you don't have that bar swapped with the overhead bar that runs from driver to passenger side.
It's super rare that it could be nearly a full inch off - these are all built in a fixture but hey, accidents do happen. If we determine that a replacement bar needs to get kicked out in the mail ASAP under your lifetime warranty then no issue. Happy to get it sorted out.
Old 12-13-2015 | 07:58 AM
  #24
Wrangeler X's Avatar
Originally Posted by Rock Hard 4x4
Yep - we're listening! We're probably one of the most active sponsors on JKF - happy to help. Couple things to check. The angle you have on the driver side looks like it's orientated wrong, the collar doesn't look like it'd come down and grab the upright and seat properly. Flip the bar all the way over and see if that lines up better. Make sure you don't have that bar swapped with the overhead bar that runs from driver to passenger side. It's super rare that it could be nearly a full inch off - these are all built in a fixture but hey, accidents do happen. If we determine that a replacement bar needs to get kicked out in the mail ASAP under your lifetime warranty then no issue. Happy to get it sorted out.
Thanks! I'll try that. I'm digging back into this shortly... Can I call someone to talk this through?
Northridge 4x4
Old 12-13-2015 | 08:21 AM
  #25
Former Vendor
Also if you see DaK on a trail - you owe him an adult beverage. He sent me a ping saying to check your thread.
Jeepers looking out for Jeepers. Love it!
Old 12-13-2015 | 08:34 AM
  #26
Also if you see DaK on a trail - you owe him an adult beverage. He sent me a ping saying to check your thread. Jeepers looking out for Jeepers. Love it!
You've got it... Thanks Dak
Northridge 4x4
Old 12-13-2015 | 08:38 AM
  #27
Rock hard
Sent you a pm. Can we get on the phone together?
The dash bar only goes in one way. As for the orientation. I'm not seeing what your talking about.
Northridge 4x4
Old 12-13-2015 | 08:47 AM
  #28
DaK's Avatar
DaK
Northridge 4x4
RH's CSR is top notch. They'll get it sorted out.
Old 12-13-2015 | 10:44 AM
  #29
Rock hard. I'm 48.5" inside seem to seam. This bar is too short! I have tried everything and have to throw in the towel.
Very disappointed!
Northridge 4x4
Old 12-13-2015 | 11:00 AM
  #30
Ripa777's Avatar
Rock hard. I'm 48.5" inside seem to seam. This bar is too short! I have tried everything and have to throw in the towel. Very disappointed! Northridge 4x4
Did u do a prefit install before u had it finished?
Quick Reply: Rock hard cage powder vs paint and what color
