Rock hard cage powder vs paint and what color
I went with Line-X and am very happy with it, though it makes fitment much more challenging.
When our cage first went in I was annoyed with it. Damn thing was everywhere around the windshield. Now? Don't even see it. Our is flame red, or as close as you can get to it in a powder coat and gloss. The reflections are not bad off of it or into the windshield.
For your cage, do a dry fit first. This is where you will do all your cutting and trimming of the jeep interior. You can google some awesome examples of some very clean installs. You do NOT want to do this after powder coating as there is a good chance something will slip and mar the finish. BUT before you even do this take a tap and clean ALL and I mean ALL the threads. There are lots of burrs from the machining process. Fit test the entire cage, this will also ensure you have all your parts. When you load up to go to the powder coaters, double/triple check to ensure you have all your collars. Know one dumbass that left two collars behind in his trunk and had to go back to the powder coaters because he is an anal ass. (yes I just wrote that). Anyways, once back from the powder coating process re tap ALL of the same threads again as the powder coat will get into the threads and be PITA during install and you do not want this frustration during install. When installing the collars start the two center bolt first, then the other 4 can be started. Tighten the outer four first in a star or cross pattern, then finish with the middle. The bolts/collars should not bind, if they do, back 'em all out and start over. Patience is a must during this stage. Blue tape is your friend, use it and be generous with it. Any questions contact their CSR. He answers emails any and all the time. If needed you can even get him on the phone.
Congrats on your cage. we love ours. we now have gauges, SPOT, tablet, GPS hanging from ours.
When our cage first went in I was annoyed with it. Damn thing was everywhere around the windshield. Now? Don't even see it. Our is flame red, or as close as you can get to it in a powder coat and gloss. The reflections are not bad off of it or into the windshield. For your cage, do a dry fit first. This is where you will do all your cutting and trimming of the jeep interior. You can google some awesome examples of some very clean installs. You do NOT want to do this after powder coating as there is a good chance something will slip and mar the finish. BUT before you even do this take a tap and clean ALL and I mean ALL the threads. There are lots of burrs from the machining process. Fit test the entire cage, this will also ensure you have all your parts. When you load up to go to the powder coaters, double/triple check to ensure you have all your collars. Know one dumbass that left two collars behind in his trunk and had to go back to the powder coaters because he is an anal ass. (yes I just wrote that). Anyways, once back from the powder coating process re tap ALL of the same threads again as the powder coat will get into the threads and be PITA during install and you do not want this frustration during install. When installing the collars start the two center bolt first, then the other 4 can be started. Tighten the outer four first in a star or cross pattern, then finish with the middle. The bolts/collars should not bind, if they do, back 'em all out and start over. Patience is a must during this stage. Blue tape is your friend, use it and be generous with it. Any questions contact their CSR. He answers emails any and all the time. If needed you can even get him on the phone. Congrats on your cage. we love ours. we now have gauges, SPOT, tablet, GPS hanging from ours.
Thanks for input guys!
JK Forum Regional Rep
Powder Coat for durability.
If you are worried about matching you jeep's color, do black or a second accent color (maybe green or go McDonald's Red). But if I had a yellow jeep, it would be a yellow cage.
I'm pretty short and have a little trouble seeing over my cage, but I got used it rather fast. Never noticed had any windshield reflections of the cage.
Your JK looks great and the cage will add some nice safety and style.
More with the way it frames the windshield on the sides and bottom. Eyes were just drawn to it, probably because it was new to the view. And yes, got used to it within a week.
Definitely make it yellow. Myself and my buddy both installed cages around the same time. Both white two doors. I powder coated my cage black, he painted his white to match the jeep. Now every time I see his jeep I have white cage envy. Lol. It looks so much better color matched. Lol
Ok went yellow but now... The dash bar seems way too short!!!
Experiance..??? I think this dash bar is 1" too short!!
Anyone from Rockhard listening?
Northridge 4x4
Northridge 4x4
Buddy of mine said to leave the side posts unfastened, and ratchet strap them to make the horizontal bar fit.
