Rock Hard 4x4 3RD Row / Accessory Mount Sport Cage for Jeep Wrangler JK 4DR?
Anyone running this or have seen it up close? Rock Hard 4x4 3RD Row / Accessory Mount Sport Cage for Jeep Wrangler JK 4DR 2007 - 2015
For those of us running a 3rd row, (I know, I know, lots of opinions on both sides of this), I know this is on my mind. I am just wondering if this is a tried and tested product or if it is theoretical?
I have a new welder on the way and already have a pipe bender that works up to 3" OD pipe. I am hoping the guru's here can help me determine if the bolt on or DIY method would be stronger. Thanks in advance!
Former Vendor
In your specific situation here's what I'm suggesting, and it's not a sales tactic, it's an opportunity for you to become a believer in our locking collar. Order our RH-1032 and do a test install before you powder coat / paint it. Tap the holes, use some WD-40 on the bolts, and as you start tightening the hardware it'll all make sense. You are simply unzipping your factory cage padding cover so you'll do zero permanent modification to your Jeep for the test fit. Do an install and see for yourself. Stand on the part. If you aren't sold, send it back.
Thanks for both responses. I certainly don't want anyone to crash just so I can give it a thumbs up. I also hope I didn't come across as if I was bashing the product. I was excited and relieved to find this yesterday. I will give it a try. It sounds like even though you could install it with the hard top on, I will pull it.
Thanks again!
Thanks again!
