on road suspension question
#21
you might all think I am crazy, but I did not by my '08 2dr X to run off road. As a matter of fact, it will never rock climb, mud, or anything else off road. I use it mostly for winter driving in the northeast. I am more of a sports car driver and when the weather is nice, I drive my '87 Porsche.
Anyway, my question is whether there are any suspension kits out there that give our vehicles much better on road handling characteristics. I am willing to give up a lot of the vehicle's off road capabilities to gain on road handling.
This is my first jeep so I am not very experienced with what is out there. Your help is very much appreciated.
#22
The Rubicon Express or Mopar long arm will give you the best on road handling. It makes compromises but if you're not taking it off road, they don't matter.
http://www.northridge4x4.com/proddet...p?prod=RE-7343
You'll want to get some bigger A/T tires, it will just look stupid if you don't. Toyo Open Country A/T's
http://www.4wd.com/productdetails.as...9&partID=16091
For shocks Old Man Emu or Bilstein. But you might want to call Dave at Northridge 4X4 ( 360 340-0282 ) and see what he recommends for what ever type of ride you want.
OME
http://www.northridge4x4.com/proddet...=OME-NITRO-LTB
Bilsteins
http://www.northridge4x4.com/proddet...?prod=BIL-5100
OME
Bilsteins
#23
OME
Bilsteins
OME
Bilsteins
what are these compromises u mention? since i have the 4.5" RE LA, im curious about the compromises u say. if he is looking for on road performance, i do not recomend this lift, it rides hella good, but its for offroad and i sure as hell wouldnt spend $3000 for onroad suspension
#24
uhhhmmmmm, you realize Re lift and mopar are the same??
#26
Several suspensions provide better ride and few provide better handling. Case in point the AEV product.
#29
I would grab a stiffer rear sway bar, I believe Full Traction makes one, and then roll from there. A stiffer rear sway bar is going to reduce body roll and reduce understeer. From there I might move on to shocks and perhaps some spacers to get the vehicle in balance.
Beyond that, I can't think of much I would do with the intent as listed. A Wrangler probably wasn't the right fit for what you want to do with it and throwing money at it is a bad path when you likely won't get to a point where you're happy with the performance.
