Rk rear arms question
I should have added... You may want to move your sway bar back. You can use the existing rear mounting holes for the front of the bracket, and drill new holes for the rear.
-another question not really related to the arms but has anyone trimmed the inner fender in the rear, like the pinch seam of the actual fender? If so can you provide pics?
You can disagree with me all you want buddy.... it tickles me.
Working fine is relative I guess and okay... you are right. They work. You slide them in and they stay in place.
Do they correct the bow they were designed to correct...... not in my experience.
I had initially purchased RK wedges to correct my coils, but after adjusting my pinion along with the axle being pushed back a little bit, there's no way they would have worked.
