RK lift question
RK lift question
My rear passenger coil spring has been rubbing on the track rear track bar.
I have the angle spacers on right, its just barely rubbing. I just hear the noise sometimes going over large bumps and its kind of annoying.
Anyone else have this problem..the lift is a RK.3.5 mid arm on an unlimited JK.
So i need to shorten them up a bit then?
All my control arms are adjustable. So if thats it, then thats no big deal then. I didnt notice any rubbing issues on the drivers side..
Thanks in advance
Thanks in advance
didnt want to start a new thread, but i just had some 37s put on and they are wider then the previous tires.
anyway the upper control arms are rubbing the tire. Im going to loosen the nuts and roll them back toward the jeep to correct it. the jeep stuff is new to me so forgive me if this is stupid. Just wondering if there is anything to do to help keep them from rolling. I know they move due to the joint. guess just keep an eye on it.
The wheels i have are 9 inches wide and 4.5" of backspacing. tires are 37x12.50s trail grapplers
didnt want to start a new thread, but i just had some 37s put on and they are wider then the previous tires. anyway the upper control arms are rubbing the tire. Im going to loosen the nuts and roll them back toward the jeep to correct it. the jeep stuff is new to me so forgive me if this is stupid. Just wondering if there is anything to do to help keep them from rolling. I know they move due to the joint. guess just keep an eye on it. The wheels i have are 9 inches wide and 4.5" of backspacing. tires are 37x12.50s trail grapplers
I fixed it today....Im sure I screwed it up when I installed it a few year back, but my tires were narrow enough I didn't have an issue. on the drivers rear side the bar was rolled out toward the tire. So I had to take it off and holy moly was those suckers seized.....another mistake I feel I made was to not coat the threads with anti seize. anyway, lesson learned.
Next id like to maybe get into the JKS rear coil spring brackets. Looks like those are a nice fix to the bend that I have in the coils. Also maybe something to relocate the track bar. JKS has some nice things I have been checking out.
