Rk krawler joint
Old 11-07-2019, 08:06 AM
G.A.H's Avatar
Default Rk krawler joint
I was tightening the jam nuts on all my control arms after i got the jeep aligned and noticed that all the joints are loose and some joints have play in the and i only have 3 to 4k miles on the lift only on road use and while taking a look at the joints i noticed that all the balls in the joints have a rough finish is this normal for these joints
And how was your experience with RK lifts and their joints
Old 11-07-2019, 09:55 AM
resharp001's Avatar
Received 1,932 Likes on 1,691 Posts
I have a feeling you know the flood gate you've just opened
Old 11-07-2019, 10:04 AM
G.A.H's Avatar
Yeah maybe but i really want to know if I'm the only one having problems with this lift ( from missing parts that got shipped back, to faulty front springs that got replaced, then the front trackbar, now the rear upper control arm joint)
Old 11-07-2019, 10:42 AM
karls10jk's Avatar
Let's try tagging @Rock Krawler Suspension and the other suggestion would be to give them a call with the number they gave you in the other thread. I do not have enough experience with their joints to give you any further info.
Old 11-07-2019, 10:48 AM
G.A.H's Avatar
I wish i can call them it will cost me a lot cause I'm not in the us and i really would like to know how was everyone else's experience with their lifts and joints so if you've ever had any of their products just let me know how did it work for you and if you had any problems with it
Old 11-07-2019, 10:54 AM
resharp001's Avatar
OP has been in the support thread and gotten the company line before. I think just looking for some unbiased opinions.
Old 11-07-2019, 10:58 AM
G.A.H's Avatar
Yup that's right
Old 11-07-2019, 02:18 PM
jadmt's Avatar
I have had and RK and never again. I have had two sets of rear coils sag and got the run around before they finally admitted they were sagged. on the second set I just threw in the towel and went a different route and never had another issue with sagging.
Old 11-07-2019, 09:53 PM
Sunnysideup's Avatar
I have Rock Krawler arms... and I used to have the joints too... I rebuilt them two times, replaced them once in a period of 8 years.
Now I'm replacing them with johnny joints from Currie. Get the right threads and joint width... etc... and then I'm threading them in to the Rock Crawler arms. No joint is free from needing some TLC now and again... there could be options that need it less... I'm gonna try the Currie joints this time.
Old 11-08-2019, 04:32 AM
G.A.H's Avatar
How did you service them, and how where you able to tell that it's time to rebuild them ? And when you grease them how many pumps did they take cause most of them took like one or two pumps before i started feeling resistance and i stop pumping or should i keep going until i see grease coming out ?? Cause I'm scared on putting too much grease in and ruin the joints.
Quick Reply: Rk krawler joint
