RK 2.5 vs 3.5 with 37's
Old 06-27-2013, 07:52 AM
Former Vendor
TOTL Innovations's Avatar
I went with an RK 2.5" long arm set up and 37s. You will have to have flat fenders, proper bumpstops and a good deal of pinch seem trimming in the rear
Old 06-27-2013, 08:52 AM
Chaseit1's Avatar
I too went with the RK 2.5,Flat fenders and adjusted Bumpstops Running 37's. You definately get more than 2.5"
Old 06-28-2013, 08:34 AM
Maertz's Avatar
Originally Posted by JKred
You can run 37's with either height spring. You will need to same bumpstop lengths for either lift (as bump stops are selected based on tire height and NOT lift height), and therefore likely the same length shock. Bumbtop legth will depend on fender choice. So it becomes a question of how much uptravel vs downtravel to you want. The taller the lift, the higher the belley clearance but the less down travel you get, however you get more up travel.
This x2 also depending on your shock travel you may want the longer coils to help keep them seated.
Old 06-28-2013, 09:40 AM
pontiac31's Avatar
I run the 3.5" x factor with out bumpstops and with cut flares stuff the tires pretty good. This kit has endless flex!
Old 06-28-2013, 10:45 AM
Former Vendor
RiverCityOffroad's Avatar
I'm running the 3.5 X-Factor with 37" MTZs and Poison Spyder narrow flares. I've toyed with the idea of dropping back down to 2.5 coils, but I really like the way it sits with the 3.5 coils.
Here it is with stock flares:
Old 07-01-2013, 06:42 AM
Yellowfin's Avatar
Damn, Marcus! Your JKU looks sweet! How is I haven't seen it until now?
Hopefully soon I'll get to spend more money with you. I've been Jonesin' for PSC flares for a couple years now.
Old 07-01-2013, 09:21 AM
devwil68's Avatar
Running the 3.5 with 37" MTZs and flat fenders, Smitty XRC front and rear bumbers....love this lift. Installed myself.
Old 07-01-2013, 07:05 PM
Matt O.'s Avatar
Factor in all your variables. I went with the 3.5" with 37 KM2's and it is too much lift. Why? I kept my build light, BFH bumpers front and rear, no spare, small winch. 2nd my tires run way small, so they are closer to a 35 than a 37. I am dropping to a true 35" tire and the 2.5" coils
Old 07-01-2013, 07:48 PM
Former Vendor
Rock Krawler Suspension's Avatar
Originally Posted by CTomlin19
I still cannot decide which kit I would like to get for my four door. If anybody has this kit could you post some pictures of it and what you think about it. Thanks
Either lift height you choose as you can see will tuck a 37" tire under it! We recommend flat fenders for both lift heights if running 37's. You choose which best suits you a little more ground clearance or keeping the rig low with a meaty tire under it.
RK
Old 07-02-2013, 07:27 AM
Yellowfin's Avatar
Good ol' Bridgeport! Just went a couple weeks ago and I'm ready to go back again. Haven't wheeled much in the last year and I'm itchin'!!!
