RK 2.5 lift ?s
RK 2.5 lift ?s
Ok I searched and didn't find the answers to my ?s. I am going with the RK 2.5" stock mod (cause I'm a poor bastard till I start the new job) and need to know what else I'm going to need. Rear track bar, drive shafts, or what else if and hopefully nothing. Already have bilsteins 5100.
Going with this for now because the sag from the PSC brawler and winch and cost effective. I hit trails but not as often as id like. And thanks for the heads up.
Former Vendor
If you have a 4 door, you should be good to go. If you have a 2 door, I would lean a little more towards the 2.5" Mid Arm Flex System.
As you concider upgrading, work your way to the 2.5" Flex System, then to the 2.5" Max. Travel System as your off-roading and or needs progress.....
Thanks for chosing RK>..
RK
RK
I have the same lift on my 08 '
2.5 mod lift, 35 MTR's w/ Kevlar, crown extended brake lines, JKS rear track bar, rough country disco's, full traction shocks, EVO gussets and thats about it, i have no problems running this as my DD or offroad. no complaints with the lift at all either
