RK 2.5 or 3.5? and bilstein or fox?
Old 06-06-2012 | 03:11 PM
dowayno's Avatar
Originally Posted by likes2jeep
So it is time to lift the JK. I have a 4 dr 2011 rubicon and I will be running GY MTR 35 with kevlar on my 17" stock rims with 1.5" spider tracks spacers. I am still waiting for the quote from Northridge Canada for the parts. I have to decide which height to go. It sounds like if I go RK 3.5 mid arm flex, I will need to change drive shafts soon. If I go with 2.5 max travel system, which is almost same price, I could get away with not changing drive shafts. Since I wont be running anything bigger than 35, I think 2.5 should be plenty.
Also what shocks should I get? Bilstein or fox. The information I am getting about shocks do not match. Its my daily driver but I go wheeling almost every weekend. Our terrain is mountainous, wet, rocky and slippery. Please chime in your opinion. Thanks...
In December I installed the 2.5 RC with BDS fox shocks. Great lift, the shocks are finally starting to mellow out after 5000 miles. My nitto 35's barely fit in the rear and some trimming will be needed in the future.
But, I must say, 4dr's really look sweet with 37's over 35's.
Good luck!
Old 06-06-2012 | 03:13 PM
finfreeze's Avatar
How is your drive shafts? did you change them or are you still running stock shafts? Thanks...[/QUOTE]
I tore my front shafts boot about 30 min after I installed the lift with the sway bar disconnected. I still have the stock shafts and just grease the slip and zip tie the boot every once in a while. The front shaft also rubs on the transfer case skid plate when it flexes really hard so mine has a shiny ring around it haha.
I'll get new shafts eventually but it works great right now.
I have had zero issues with the rear shaft.
Old 06-06-2012 | 03:53 PM
FlameRedJK's Avatar
I run the RK 3.5" X-Factor with the Bilsteins and I think they are great!
Old 06-06-2012 | 04:05 PM
chris@offroadevolution's Avatar
Sponsoring Vendor
You should consider looking at King Shocks. They can be valved to fit your needs. If you dont like the ride, it can always be re-valved. You also should match your shocks with the coils. When the shock is valved to the specific coils you get the best ride
Old 06-06-2012 | 04:06 PM
rb1boxer_3's Avatar
I run the fox 2.0 with my rk3.5" max travel and don't notice nothing different yet only drive it like 3 miles then had to go to work. But I'll let you know when I test it Friday.
Old 06-06-2012 | 04:44 PM
monkers's Avatar
I have the 2.5 Max Travel, Fox 2.0 IFP shocks and love it!! Rides, firm, but not harsh, handles great on the road, very happy, I also have 37" Nittos, with 3.5 kit your 35s may look a little small, just my 2 cents.....
Old 06-06-2012 | 04:57 PM
likes2jeep's Avatar
Thanks to everyone here for your ideas . This was very helpful. I think I will go with 2.5 because this is what I need at the moment. Good thing about RK is that they are upgradable.
I will check the King shocks too, Chris. Hopefully I could get my next mod in your shop. It would be nice to take a road trip towards south. May be we could turn it into a monster jeep at that time When I bought my jeep, I didnt think I was going to off-road it but then I wheeled every weekend. Now I am thinking I wont go over 35s but that might change too
Old 06-07-2012 | 07:55 AM
Merlin4979's Avatar
I asked this very question to someone who has actually run both brands & basically the Fox vs. Bilstein issue is basically a wash. They're both great shocks. Here's the answer that I got:
Originally Posted by RiverCityOffroad
Bilstein 5100 vs Fox 2.0 IFP is a wash. The Fox shocks are heavier duty but don't have as much travel as a Bilstein do you have to run shocks that don't correlate with their listed lift heights. If you're going to spend money on shocks I would look to adjustables or RRDs before a remote res unless you're bombing through the desert when you wheel.
Marcus
