RIPP Supercharger Real World Owner Experience
#91
[QUOTE=blockrockin;1629799]I'm interested in the sprint booster ... what exactly does that do ? i have the ripp supercharger.. works great.. i do keep getting a check engine light for o2 sensor ? I'm not sure how to fix that.. comes on about 30 mins after Ive been driving ... i sent ripp and email but havent heard anything yet ?
you are running de icer for meth shot and pump is adjustable ive heard running to much meth will screw with o2 sensor
![Don't Know](https://www.jk-forum.com/forums/images/smilies/z0tdntknw.gif)
#92
Its been A while since I have been on I've been too busy working in the hospital, but the Ripp SuperCharger and what they claim is true. Excelent customer service #1
, Reliable product, and true performance. I have been driving my supercharger around for some time and it def was worth the price. The research and time put into these kits are second to none. When you get your product it is solid and dependable and carefully done and thought out. If you have any problems with the kit which I doubt give Ross and crew a call they def know this jeep inside and out. The only problem i seem to have since I have had the supercharger is that you go through tires really fast because you can't stop lighting them up
. My black Sahara Jeep with exhaust that Ross customed tuned has never made me happier. Thanks guys!
![Thumb](https://www.jk-forum.com/forums/images/smilies/thumb.gif)
![YA Dance!](https://www.jk-forum.com/forums/images/smilies/wings.gif)
#93
Amstellight if your looking for tires i have tires and rims off 2010 sahara with only 2000 miles on them pm me if need
as far as the ripps kit so far so good work great and is a very clean install
![Clap](https://www.jk-forum.com/forums/images/smilies/clap2.gif)
#94
[QUOTE=Slacka;1630011]
Water/Meth will cause O2 sensors to fail after long use with meth. That's just part of the game in the FI world.
you are running de icer for meth shot and pump is adjustable ive heard running to much meth will screw with o2 sensor![Don't Know](https://www.jk-forum.com/forums/images/smilies/z0tdntknw.gif)
#95
#96
[QUOTE=blockrockin;1630803]Not sure, What codes are you throwing? How long have you had the kit? If not long I dought it's a bad O2 sensor. I have had to replace a few before in FI cars that I have owned when spraying meth. But I always used a strong mix 70/30.
#98
. My black Sahara Jeep with exhaust that Ross customed tuned has never made me happier. Thanks guys! ![Thumb](https://www.jk-forum.com/forums/images/smilies/thumb.gif)
Overal my take is this, the Ripps Mods Super Charger is a VERY well put together kit. The components have proved they can take a beating as has the JK! The power this thing makes is great. I can cruise all day at 70 mph without difficulty and easily hit 85 mph (not that I would do that on anything other than a closed track
![Wink](https://www.jk-forum.com/forums/images/smilies/wink1.gif)
ONE BIG CAVEAT!!! It has to be installed correctly. The mechanic who installed mine did fine on the actual mechanical parts but fell down when it came to the wiring. He just plain made several wiring mistakes! I corrected this and it ran great for 24 hours until the wiring harness for the "black box" wrapped aroung the steering shaft and shorted everything out!
![Hit the Fan](https://www.jk-forum.com/forums/images/smilies/hitfan.gif)
![Duh](https://www.jk-forum.com/forums/images/smilies/sFun_duh.gif)
![Bad Day](https://www.jk-forum.com/forums/images/smilies/badday.gif)
![Yup](https://www.jk-forum.com/forums/images/smilies/yup.gif)
#99
I was checking out the charger forum and it seems like a few had a problem with the codes you are getting but no one had a fix. That I could find.
#100
It's hard to say if the O2's are bad to be honest. If I were you I would pull one of the o2's out and see what it looks like. If it is covered in a white dusty film it probably is bad. And it would also indicate it is running lean. Even If you replace the o2 sensors you might be fine for awhile but it might come back. That's just one thing I always hated about FI is your opening a can of worms on a NA (naturally-aspirated) engine that wasn't meant for Forced Induction. But it's all part of the game to get more power.
great thanks alote for your help.. ill check the o2 sensors.. ill take a look see what they look like.. guess i should check all 4 ? how much do they run if i need to replace them ? the code pops up almost exactly 30 mins after ive been driving.. i guess once things heat up .. thanks alote
