RIPP Gen 2 MAP sensor
SO a few months ago I installed a gen 2 upgrade to my RIPP and from some previous posts you can see i ran into one or two hick ups but went pretty smooth since then have had some interesting developments.
The error codes i recived after the install for the SCM was due to my clock spring being bad and the dealer fixed that under warrenty could not belive that.
Now the bad...I was getting a mild vacum leak and could not pin it down but the dealer did, My map sensor from RIPP had cracked and was causing the leak so i had to get a new one.
Any one else had any issues with the MAP sensors breaking or am i just an unlucky bugger.
