RIPP G2 - Need interim tune advice!
hey All,
I completed my RIPP G2 install on Thursday and have been waiting patiently for RIPP to return my 'tune'. They said I'd get it yesterday or today - however, theyre closed on the weekends and I really need to get the Jeep back on the road.
What tune can I use to drive the Jeep? I believe I have two options, both with concerns.
Option 1 - install the stock belt, keep stock tune. Will the new injectors and plugs be fine with the stock tune?
Option 2 - the predator came with a pre-installed SC tune. Should I use that?
HELP!! I can't miss another day of work, nor can I deal with my wife bitching and moaning another day about this.
Installed the SC tune from the Predator (not my custom tune) and she runs! Not well, but she runs. I was able to double check all my connections and everything looks fine. Unfortunately, she stumbles at 2.5k and struggles going up my driveway. Definitely not risking the 90 mile commute to/from work.
Calling out from work today with hopes my tune will arrive sometime today. If not, then I'll be shit out of luck for work tomorrow and Monday.
DOES ANYONE KNOW IF RIPP HAS UNPUBLISHED WEEKEND HOURS? If so, I would really love a direct number or a contact so I can get this resolved today.
There isn't a stock tune for the supercharger on the predator. The only way to drive the vehicle is to get the tune from RIPP. You could put the stock map sensor back in and the stock injectors all with stock belt. I ran into the same situation and ended up having to rent a car until I got the tune.
![doh](https://www.jk-forum.com/forums/images/smilies/doh.gif)
Guess I'll call Enterprise and have them pick me up.
![Smile](https://www.jk-forum.com/forums/images/smilies/smile.png)
THANK YOU RIPP!! Got my tune this afternoon and I just installed it.
Unfortunately, I'm having some minor issues.
1. When starting the Jeep, it doesnt roar to life like it used to. When I turn the key, it'll stumble at ~200rpm's, then about a second later go to a steady 800rpm and sit there. If I start the motor when cold, it'll take 2-3 tries to get it to turn over. I've got a video and will post it shortly.
2. At 2,000rpm's at part throttle, ie- 25-30mph uphill, the power isnt linear. There's a weak spot at 1.8k-2.2k where it feels like it hesitates. I'll double check the bypass valve and check my hoses for boost leak.
Or are both of these conditions normal?
Did some research on these forums, and I'm very pleased with the amount of info available here.
Both issues have been discussed in length and I believe I need to find a happy medium between my throttle settings and the adjustment of my bpv. I also need to identify any leaks too. During the install I noticed the lower egr gasket looked like it was on its last leg, and that sonofabitch pass rear bolt holding the intake manifold may not be as tight as it should be.
I'll play with some configs tomorrow and if all fails, I know the guys at ripp can help on Monday. For now I'm going to have a very well deserved tall glass of some 16yr Lagavullin.
You might consider posting your issues in the following thread which has sort of become the default place to discuss problems (you'll at least want to read through the thread if you haven't already) ---->> https://www.jk-forum.com/forums/show...-Gen-II-Issues
Edit: While I was replying, looks like you might have found the stuff I mentioned above.
So here's the video. I need to figure out how to adjust my throttle sensitivity settings now...
http://youtu.be/A1adhZXAieM
