rim spacers and 35" tires
i know i need the spacers on the stock rims if i go to a 35x12.5 tire but if i by new rims can i fix this problem by changing the back spacing. if so what would be a good back spacing for a 10" wide 16" rim
![Thinking](https://www.jk-forum.com/forums/images/smilies/thinking.gif)
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
Start in the Wheels & Tires area of the FAQ. It's stickied at the top of this modified section...
https://www.jk-forum.com/forums/show...74&postcount=3
Don't worry about your offset,
just make sure you buy rims with 4.5" backspacing or less.
See, it takes even less effort to answer the question than to berate you and make you go look someplace else without any more info that you had when you asked... wow!
![Clap](https://www.jk-forum.com/forums/images/smilies/clap2.gif)
i under stand what you're saying with the same questions but searches seem to be inaccurate and horwitzs is right in what he said
