Riddler Diff. covers
I have a question for you guys on the my newly installed Riddler diff. covers. Once I filled the front with gear oil to the bottom of the fill plug I drove it for a while and stopped for bit and I noticed that the oil was coming out of the axle vent tube. H as anyone had the same problem and what did you do to fix it?
![Thinking](https://www.jk-forum.com/forums/images/smilies/thinking.gif)
JK Forum Regional Rep
![](https://staticssl.ibsrv.net/autocomm/Content/JK-Forum/jkamicon.png)
The holes are mounted higher than stock because lifted vehicles can cause the differential to rotate and be at a different angle than stock.
I run Riddler covers front and back and use the factory fill spec:
FRONT AXLE ± .03 L (1 oz.)
186 FBI (Model 30) 1.0 L (1.05 qts)
216 FBI (Model 44) 1.3 L (1.35 qts)
REAR AXLE ± .03 L (1 oz.)
198 RBI (Model 35) 1.83 L (1.9 qts)
226 RBI (Model 44) 2.25 L (2.4 qts)
