Richmond Lock Right for my Dana 30 3.73 which model number?
I am having a hard time trying to find the correct model number for the Lock Right lunchbox locker for my front diff. Any help is appreciated.
Former Vendor
2210-LR
The carriers on the JK D30 are the same as the past carriers in regards to the Lock Rite...(xj, tj, yj, etc.) As long as you still have 27 spline axle shafts this will work.
Yes there is a split in carriers as far as gearing goes (3.73 and down, 3.73 and up) but that difference is only in the mating surface of the ring gear. It moves the ring gear closer to the pinion gear so you can get the correct back lash for the numerically higher gears. Everything else is identical.
Here is a picture.
We used a JK carrier in our XJ with 4.56 gears. Same part number.
We have one in stock if your interested, PM us for a quote.
Here is a picture.
