Rhino Line or Linex?
I am going to have my bumpers, front and back, redone by one of the above. I just can't decide which one. It seems that at least in the city that I live the Rhino Lining is quite a bit cheaper. I was looking at have the interior possibly done, also. Which will stand up the best? Which looks the best? Any other things that I should be looking at? Thanks.
I had my Mopar bumper with tire carrier Rhino lined everything including bolted areas. I would suggest removed anything with bolts first before you do it. If you dont and later wanting to take a particular bolt off, you're going to peel some of the liner off around that area.
I did LINE-X on my truck and plan on using the same when I do the inside of my tub on my jeep. I will opt for the line-x extreme, or whatever its called, suppose to be fade resistant.
The Line-x is a "cleaner" look, all of the edges are sharper where they finish it. Also the rhino is a softer liner
I believe that line x is hot cured or at least sprayed hot, the finish is softer to the touch. Rhino is cold cured and ends up very hard.
Personally I like line x but that's when it comes to truck beds. Putting furniture and stuff on a rhino bed usually meant that the furniture came out scratched. Line x is much gentler.
Don't know how that translates to good bumper coating. Line x was used in the trucks on my wife's dariy and so far they have held up good to all the abuse.
When I spray my tub it will be line x
I've used Rhino on several things in the past, and I had my tub rhino'd a few months ago. I went with it because it was cheaper, so I was able to have it sprayed thicker to provide more insulation. It made a significant difference in getting rid of some road noise.
I just line-xed my Lod shorty tire carrier. I have not yet installed. I will try to post pictures soon with the install.
waiting to get the LoD rock crawker stinger so I can line X and install at same time
so far it looks great. I did get the extra? uv protection
