Replacing control arm bolts ( Grade 8 ) Questions ??
Old 08-23-2014 | 05:43 PM
mhockey9090's Avatar
Vet Army
Default Replacing control arm bolts ( Grade 8 ) Questions ??
I am about to replace them tonight and re grease my adjustable controls arms. I can't really find anything that says the best way to do so. I know when putting the bolts back into place the easiest way is to use the jack in different places on the axle to get the bolt holes to line up with the control arms to get back in im just curious about taking out.
Should I ?
Jack up the Jeep,take off tires, and allow axle to hang when taking out bolts?
or
Take them off with the Jeep on its own weight with tires and everything on?
Thanks guys
Old 08-23-2014 | 05:49 PM
catahoula's Avatar
It would be way easier to take off tires. Can you support jeep on stands then use floor jack for arms?
Old 08-23-2014 | 05:53 PM
Vet Army
Yes i have a jack and jack stands so either way i can get it done. Just looking to see how most have done it. Ill just start jacking up the Jeep right now then .
Old 08-23-2014 | 05:59 PM
ronjenx's Avatar
When I did mine, I put some frame weight on jack stands, with the tire still on the ground. This kept hole misalignment to a minimum.
Do one at a time. If the control arms need some aligning, just roll the tire a little. My track bar didn't need any alignment, as the frame and axle couldn't move sideways.
Just snug the bolts until all the weight is back on the tires, then bring them up to torque spec.
This technique worked well on mine and a few others I have done.
Old 08-23-2014 | 06:00 PM
Hoopskier's Avatar
I would say, if you are just removing and replacing the control arm bolts, just leave the jeep on the ground. On the ground, tires on, parked in a level space, and do one bolt at a time. The bolts should be torqued with the weight of the vehicle on the axle. I put control arm drop brackets on mine, and never needed a jack. By doing one at a time, the axle is not going to suddenly roll away. You can also use the tire to push or pull the axle to help line up the bolt holes, should they lose some alignment.
My .02 cents.
Old 08-23-2014 | 06:05 PM
Vet Army
Ok thanks guys im gonna try it with the Jeep on its own weight first and see how fast that goes.
Old 08-23-2014 | 07:54 PM
Vet Army
Got them on with all the tires on the ground without any issues. Just used the jack to help align the bolts back through.
