Replaced ball joints but still have minor wobble
hey fellas I got a wobble normally around 40-50 and 20-30mph with minor to moderate throttle. not when I take my foot off the throttle it immediately goes away. my ball joints were shot anyway so I had to replace them but thinking this can make a wobble it would go away when I fixed them. Wrong. I still have the wobble at those speeds and I don't know what it could be I was thinking I need an alignment or maybe one of my tires is not correctly balanced.
Well, may as well start with free stuff. Check the tie rod ends and drag link ends for wear. Assuming those are good, it could be the tires or a hub. Given that it is speed related, that implies tire related. Have you tried rotating the tires and seeing if that makes a difference? Just swap front to back for the test.
Your alignment would have to be really messed up to create a wobble. Also make sure everything is tight. All it takes is one loose bolt.
