removing stock bumpers, question
Old 03-23-2008 | 10:15 AM
gongetya's Avatar
Default removing stock bumpers, question
I have an 08 x and want to take the plastic bumpers off for aesthetics and to make room for larger tires. Are the steel bumpers underneath okay like they are, or would I have to get aftermarket replacements?
Also, if anyone has done this, am I gonna have a hard time with removal because of the fog lights in the stock bumper?
any help would be appreciated
Old 03-23-2008 | 10:27 AM
TEEJ's Avatar
Talking
Its fairly modular...you should not have a hard time. I did take off the entire bumper, and could see that the plastic parts are ust a skin over the metal.
I imagine it cold be done ON the truck, but, When I removed the bumper entirely (not a long process, 8 bolts, plus some plastic clips for the fog light harness, plastic aesthetic parts...maybe 30 minutes total at most...)...it was VERY easy to then see/access the parts you are interested in...and, of course, it would then be MUCH easier to access/remove the remaining items, and then just bolt the bumper back on sans unwanted stuff...and be done with it.
With the entire bumper off, it ALSO gives a clear view of much of the stuff the bumper is in the way of normally...so for future convenience (Esp. if you snap off a few pics...), you already know what's under there, etc.
From a purely functional standpoint, the oem bumper under there is a std 5 mph bumper....nothing special.
If I were to have my 'drothers...I'd 'drother mount a Shroworks Stubby there to have even MORE tire clearance, PLUS some real protection of the front clip in case of trouble, the option of strongly mounting a winch, etc.
Old 03-23-2008 | 10:39 AM
pulman01's Avatar
The hardest part is snapping off all of those plastic clips. Crawl under and disconnect your factory fog lights. Then, get some needle nose or lineman pliers and start snapping/clipping off those clips. Lastly take off the bolts (8) and thats about it. The entire bumper/plastic assembly probably weighs like 10-15 pounds.
Old 03-23-2008 | 10:55 AM
gongetya's Avatar
This is exactly what I needed to know. Thanks Yall. I'm in uptown New Orleans if yall come down, drop a line
Old 03-23-2008 | 08:55 PM
jkx0778's Avatar
don't forget to post pics when you do this
Old 03-23-2008 | 09:31 PM
TxCop07's Avatar
Vet Army
its not that hard, good luck
Old 03-24-2008 | 11:55 AM
gongetya's Avatar
Hey guys, everything was going fine, my only obstacle is getting the bumper around the tow hooks...can anyone help? I don't see where I can remove the hooks with the bumper on
Quick Reply: removing stock bumpers, question
