Removing spider tran and loc-tite
Im removing my spidertrax spacers this weekend to install my new tires/wheels. Any issues or tips I need to get the lock tite off the factory studs/lugs after removing the spacers?
You can also burn it off with cutting torch but you have to hit the oxy before you move near the studs, this keeps it from developing preheat that would allow you to cut metal, and be sure keep in cut mode until you have completely moved away from the stud. You will be using the outer fringe of the flame to burn off the loctite while in cut mode. You are not trying to heat up the stud so you don't stay in one place long. If you have not done this before I recommend mocking up a bolt and nut assembly with loctite. Let it cure, then remove the nut and put the bolt in a vise to hold it while you try this method. Then you can decide it is for you.
