Removing front break bracket
Old 02-21-2015 | 05:56 PM
cody0707's Avatar
Default Removing front brake bracket
I just watched a Teraflex video where they removed the metal bracket holding the break lines in the front. I am referring to the clamp bracket near the lower shock mount. If I only need roughly 3" more to keep my brake lines from being tight at full droop is this a good option or should I keep the line clamped in the bracket and get drop brackets for the mount further up in the wheel well?
Old 02-21-2015 | 06:49 PM
Invest2m4's Avatar
There is no reason to keep the bracket. It's free to remove and a quick project. The easy way to remove them is to use a Dremel and cut the back side of the bracket. It will bend open with ease. If you don't, you'll yell profanity for an hour until you end them off.
Also, a drop bracket won't extend the speed sensor, so no sense in doing that.
Quick Reply: Removing front break bracket
