Removing a 1" Body Lift
Hi guys,
Got a unlimited with a M.O.R.E 1" body lift I want to remove. I have the bolts for stock mounts. Is it as simple loosen bolts on one side, jack up body, remove spacers, lower onto stock body mounts, insert bolts and tighten...repeat on opposite side?
Am I missing anything? Anybody done this? Should I remove them in a certain order?
Thanks
Thanks
You don't have to remove the front bumper to install it, I don't see why you'd have to remove it to uninstall the bodylift. Do just that... loosen the bolts on one side, just it and remove the spacer!
Hi guys,
Thanks
Thanks
I got a 6" RC lift on 37"s. with the 1" BL. When it's full of gear and family, it feels top heavy. I'm think without the BL it will feel more stable. I'm considering some wheel spacers also to widen the stance. Any thoughts
Thanks
Thanks
Way too much lift for 37's IMO. I would definitely pull the body lift. Or just get some 40's...
