Reinstall ball joint after welding gussets?
Old 12-08-2021 | 02:27 AM
TOMEGUNS's Avatar
Default Reinstall ball joint after welding gussets?
I did a search around the web and dove into the forums and couldn't find an answer to this.
I installed Teraflex HD ball joints about 9 months ago and have only put around 2500 miles on them. (I've been working from home and not driving much.) Since I'm not driving much right now I figured it's a good time for some upgrades. One of those is welding C gussets on my 44. Can I remove the upper ball joints and reinstall them after welding or will it mess them up?
Old 12-08-2021 | 04:53 AM
resharp001's Avatar
You can remove them and then reinstall afterward. With that upper you really need the adapter kit to get it out properly without damaging it if I recall. It's been a while, but I seem to recall the basic BJ press kits don't have the proper adapter to get it out without just pushing on the stud. Not a big deal if you're removing crapped out BJs but obviously not what you want to do if you're re-using one.
Old 12-08-2021 | 07:03 AM
MrClortho's Avatar
My installer wrapped the ball joints in a wet rag and only welded about an inch or less at a time near them. They appear to have survived fine in place...at least so far.
Old 12-08-2021 | 07:15 AM
Sv_dude's Avatar
I would remove them. Rent a ball joint press from the auto parts store. There’s adapters there that will work well with the TF ball joints.
Quick Reply: Reinstall ball joint after welding gussets?
