Regearing to stock 3.73s...would anyone even notice?
Hello,
I have 3.21 gears on the 3.6L auto with open diffs. 2013 2 door sahara. I am regearing to take-off stock 3.73s from a 2010 soon. I am getting it done at a local shop and also sticking a detroit truetrac in the rear at the same time.
I don't want to have a discussion about whether this will void my warranty, this has been discussed everywhere...but more about "will anyone even notice?" I am sure if someone discovered it, my warranty would possibly be voided and I have accepted that.
How different would it look under there with the truetrac and the gears? Would it be obvious, or would someone have to do some digging to figure it out? Will 3.73's on 33s with a truetrac even possibly harm parts of my powertrain, assuming a professional install?
Thanks, any advice/input appreciated.
If you want to hide it or make it look like OEM from the outside, black spray paint will be your friend. As soon as you take the diff cover off, any mechanic worth his salt will immediately notice the TrueTrac.
Other than voiding the gears warranty I don't see what else they could void.
By just looking at it no one should be able to tell. If your diff grenades and they open it up it will be obvious.
As far as will it harm anything, it should be fine. Not sure why you are only doing 3.7 though. Might want to think about going higher if you will ever go with bigger tires.
I am going to 3.73 because I don't plan on going past 33 inch tires. 33's with 3.73s is perfect, imho. 3.21 seems too underpowered and 4.10 on the 3.6L auto will probably be too much for 33s. I've thought about it and weighed the cost and it just doesn't seem worth it when I can get 3.73s cheaply. I haven't driven either, but this is what I've gathered from my research.
What are you paying for labor, and what are your tire size plans for the future? It makes no sense to pay to have 3.73's installed if you ever go above 33". I mean i have 35's and 3.21's but i plan to go to 4.10 or 4.56 in the future. Point being, 3.73 will work, but still won't be ideal. Just a thought
edit: just now read your reply above. I'd still get the 33's and try it out before you spend money on the regear. Grenading would refer to your ring and pinion breaking and having a fustercluck of shrapenel in your diff
Must have missed my last post. as much as I love the idea of 35s and higher gear ratio, I don't see it happening any time soon, at least not until the Jeep is paid off (lol 2019). Until then it is my daily driver, and I don't want 35s. The highest I'll go is 33s and I may even stay on 32s. I just think 4.10s would be too much for that. I would like the extra power of the 3.73s. To me the 3.21s seem a little bit underpowered on 32s. If I had 30s or 29s maybe it would make sense to not regear. Just my opinion, like I said I'm a bit inexperienced here. The TrueTrac is just an added thing that I figured I'd do while I'm regearing. I'd love to get a little extra stability in snow and rain.
The shop I go to is a one man show he quoted me $1000 for the entire job (inc. truetrac). Does that seem off? He seems really fair and not out to rip me off. I had read on here $500-$600 an axle in my area is pretty standard.
From 3.21 to anything numerically higher in the front d30, you will need to buy a new carrier also. Should be around $70 or so. Why not just spend an extra $300 and drop in another truetrac instead of buying an open carrier?
The truetrac is a very strong, full case unit. Assuming a good install (don't assume that 'professional' = 'good', since even pro's can F-Up gear installs), it should not cause any issues whatsoever. But as noted, if someone were to pull the diff cover and look, it will be fairly obvious that you now have a traction device installed.
Going from 3.21 to 3.73 would be an absolute, complete, over exaggerated, and agrivating waste of your time and money. You wont notice a big enough change to make the dent in your pocket feel worth it. Period. You're talking a 0.62 revolution change at the pinon.
The trutrac... yes very worth it. Put it in the front too, and keep your 3.21's....
A regear is usually charged 5 hours front, 4 rear, at $100/hr shop rate. This is a common rate. Usually figure another $100 for every locker or traction aid if it involves wiring or plumbing. If it's a new case/carrier like the truetrac, it shouldn't add to the cost.
I have 3.7 gears in my 13 Moab with 315 duratracs which are essentially a large 33 inch tire and Its way under powered. Now mind you I have steel bumpers and a winch plus other goodies too but I tried a 0-60 run the other day and it was 9.9 seconds. I am seriously thinking about going to 4.10 or larger. Just food for thought.
Thanks for the input bud.
