Regeared, AEV calibrated, getting high revs from 3rd to 4th - 4th to 5th
2012
4:88 gears
35"
Aev calibrated for gears and tires
90% of the time I am revving to 4,500-5,000 rpm's when going from 3rd to 4th, then 4th to 5th. I can usually let of the gas for a split second, then press back down on the gas and it will grab the higher gear. But, if I stay on the skinny peddle, it rev's to what I feel like are really extreme rpms.
It happens on flat ground, not just hills...I could understand it if it only happened when I am climbing, but that's not the case. I have even had it happen often if I peak at a hill and start downhill and it takes really high rpms to grab that higher gear.
2 things: is something up, or does this seem to be the norm?
Is there a way to calibrate for smaller or bigger gears and "trick" the engine into smoother shift points?
Let me know your thoughts and if I need to provide any more info...thanks.
4:88 gears
35"
Measure your loaded tire height with the tire pressure you intend to run and reload with your Procal. I think you'll probably find your off in actual height.
Yes the AEV Procal can adjust gear ratio.
If you've already done this, flick the switches up/down and make sure they were making contact in the correct position.
~9k, about 2,500 on the new gears. No noises or any issue with the gears either.
I paid attention earlier when I drove it and 1st to 2nd, and 2nd to 3rd all shift at around 3,000rpms. So it's really smooth on the slower end, just happens going to 4th and 5th as described in my original post.
I would set everything back to stock with the procal and then disconnect the battery for 1/2 an hour or so then reset everything. If you go to AEV's website they have a forum and they talk about on rare cases they need to do this.
