Regear: 3.21 to 4.88 Q's?
Guys, gonna be regearing my 2012 with 3.21s soon to 4.88s. Just want to clarify a couple of questions I still have.
Do I need to change ONLY the front carrier to a 3.73+? Will I need new spider gears or can they be reused from my 3.21s? I will be getting a full overhaul kit with bearing and everything.
Any additional info that I should probably know?
Front carrier is the only one that needs to be replaced, but if your thinking about adding a locker or LSD to the front nows the time, if you go with a full case design you won't need the carrier and if you go with a lunchbox style you don't need to swap out the spider gears. Plus it saves the hassle and cost of going back into it later.
I'm not sure that I want lockers just yet due to the fact that I don't really do a whole lot of technical/hard wheeling. I have a lunchbox style that was given to me but I'm not sure exactly how that would affect my drivability/steering. Can I use the same spider gears from my old carrier in the new?
Former Vendor
I went 3.21 to 4.88 and I really really really really REALLY regret not putting in a locker probably should have done both
#ionlywanttofacepalmmyselfwhenidontputlockersinmyj eepwheniregear
#thatwasmyfirsthashtag
#jeepproblems. But for real for the original question your are better of to get the stuff to run a locker whether you put them in now or later. Later you will do and be kicking yourself for not.
If I were you, I would advise getting a locker. at least for the rear. I thought i'd never use mine as well, but I have, and i'm glad that I have them. I would not use the Lunchbox, it will hinder your steering. IMO
rock
rock
