Regear
Old 02-02-2010, 07:57 AM
RubiDude's Avatar
Default Regear
OK, so I searched "How to regear" and did not find the answer. Basically, I would like to see some information, or even better a video, on the process of regearing a JK. I have a 08 Rubi and at some point would like to go to 33" (no regear for me there), but I also can not stop thinking about 35" tires either! I assume if I go to 35" a regear would be needed? Amy I right or wrong? Anyone have any links to info/video...I am a visual learner, so nothing too high tech, need to see it!
Old 02-02-2010, 08:02 AM
EstianSwanepoel's Avatar
If you have a Rubicon you can get away with not regearing but it's not gonna be ideal. Will probably have to live without overdrive and push the pedal a bit harder. Fuel consumption will also be a lot higher.
So IMO, yeah, you def need to regear for 35's
Old 02-02-2010, 08:04 AM
RubiDude's Avatar
Is it a really involved process? I am sure I could get the diff covers off, but other than that...not so sure!
Old 02-02-2010, 08:12 AM
JK-Forum Founder
wayoflife's Avatar
As mentioned, running 35s on a Rubi is tollerable but new fears would be nice to have. Having said that, installing gears is not something I would recommend doing yourself as even experienced installer have been known to screw things up especially when dealing with the factory locker. Gears are pretty much the only thing I don't do myself.
Old 02-02-2010, 08:17 AM
jeepmedic's Avatar
Check out this post. About the most informative I have found yet.
https://www.jk-forum.com/forums/jk-write-ups-39/gearing-82262/
Old 02-02-2010, 08:39 AM
RubiDude's Avatar
Nice....seriously nice post! In looking at that chart, it makes it seem like with 35" tires and 4.10 I will be in the yellow (good fuel economy). My only other concern is will I damage anything by running 35" tires without regearing. I can deal with a slower ride on the hwy and what not...I mean this is a Jeep not a Vette. However, I do not want to ruin transfer case, drivetrain etc. due to tires! I got the lifetime warranty and wonder if this would be an issue.
Aside from hwy performance, will this impact my performance in 4wd? I wheel almost monthly, nothin too crazy, but I do it and enjoy it nonetheless. Will I not be able to make it up trails or over rocks with 4.10 gears and 35" tires? Thanks again for all the info...some really good stuff here!
Old 02-02-2010, 08:50 AM
mrhumpty's Avatar
Just tossed on 35's on my 08 rubi (6speed). Runs just fine street wise and I'm about to take her for a climb this weekend but my guess is it will be just fine.
Before I regear I'm going to retune anyway. For the offroading I do I should be fine regardless. Heavy rock crawling may be a different story.
Also check out this diagram:
https://www.jk-forum.com/forums/show...76&postcount=4
Gives you a decent idea about what you may need.
Old 02-02-2010, 11:39 AM
jeepmedic's Avatar
I have 35's and 4.10s and have had no problems off road at all. In 4L it crawls like normal, but then again I dont do any major rock crawling...
Old 02-02-2010, 11:52 AM
RubiDude's Avatar
Is Jeep going to void my warranty with 35" Tires?
Old 02-02-2010, 03:19 PM
BlackNorthernJK's Avatar
It is an involved process...but are you somewhat mechanically inclined? If the answer is yes, then I belive you could effectively accomplish regearing your Jeep yourself. I would say it certainly deserves a good portion of respect it gets out there for being a fairly difficult job, but at the same time it's not out of the realm of the do it yourselfer in my opinion. A few specialty tools along with a good dose of patience and a thorough understanding of what's involved should serve you well. Myself and RCJeeper have both succesfully installed our gears in our own garages. If you have any other questions I can certainly do what I can to help you out.
Quick Reply: Regear
