Regain fuel capacity?
Interested as well. With the low fuel light on, the most I can fit is 14-15 gallons. I've pulled it down and beat it back into shape but I don't recall the capacity at that point in time. The 2dr should have a capacity of 18.6 gallons at dead empty.
Years ago I was the lucky recipient of a full set of RH skids from a contest on this forum. As a side note, that is the primary reason that I support this forum almost exclusively in an effort to give back to this particular community. Anyhow, my gas "skid/hanger" had been so dented up that I swore I had lost some fuel capacity. Before putting the new skid over the factory one, as that is how they all install, I lowered factory POS and fuel tank. It was a major pain IMO. For the effort, I'm not sure it was worthwhile. I was extra careful as to not bust one of the fuel line clips. Then, just banging the dents out of the factory unit was its own fun time. I do recall the bottom of my fuel tank being bowed up some. It seems things went back to normal after that, but that could be a little revisionist history as well as it was years ago. I recall thinking I'd never want to do that again. Maybe the limited capacity on a 2dr would make the payoff a little more worthwhile.
If it’s worthwhile I’d like to completely replace the factory skid plate with an aftermarket one. I’ve heard of people taking the factory one off, banging out the dents, and having one hell of a time putting it back on. My fuel tank only fills up to about 85%. It’s a two door.
Putting it back up isn't terrible as long as you're down on "low fuel". I use ratchet straps between the tank and the skid to hold the tank up while I work the skid.
