Red lightning bolt light!!!! Help
2014 jku with 500 miles, Red lightning bolt light thrown after aev 2.5 lift and 35's. Manual says electronic throttle control light. Made an appointment at the dealer already. Anybody been dealing with this issue??
07 jku. 103k miles. Had mine a week and the lightning bolt came on. Took it to auto zone to read the code. said it was the coolant thermostat. I changed it and the light did go off. ?
I have heard it being how you put on your gas cap too. idk. Back when I had this issue I was getting a variety of responses.
but a 14' shouldn't have that come on..
good luck.
good luck.
Ignition key: off/on/off/on/off/on (without starting).
P0223 - Throttle Position Sensor 2 Circuit High
P2135 - Throttle Position Sensor 1/2 Correlation
it could be anything from a loose connection to a faulty TPS. Just let the folks at the dealership take care of it.
