Recommended Lift Kits
One thing to keep in mind is the weight of you jeep, and the future weight of you Jeep. Different brands set up their lifts for different style Jeeps. Some, such as Teraflex are set up for light weight jeeps (stock bumpers, no winch, no armor), others like Rock Krawler and Metal Cloak are set up for more fully outfitted heavier Jeeps, and then others offer different could depending on the weight of your Jeep, like Old Man Emu.
I have the Teraflex 2.5, but have been adding weight, and will need to change out to different could in the not too distant future. I really like the way it rides with my two door, but as I add weight, I am loosing height.
Just food for thought.
Well, I would like to do over landing with my Jeep so 2.5 inch is high but not too high seeing as I'm quite short but high enough to give me more than stock clearance. It seems though that the consensus is Teraflex what does the price usually range from? As for the shocks I would like to change out the shocks for better performance but like I said I'm not too knowledgeable when it comes to lifts.
I would not recommend Teraflex to anyone.
If you are going to carry around a lot of gear with you while overloading you are likely going to want a coil that can handle more weight then most standard lifts offer. Old Man Emu offers coils with different rates to handle heavier loads better.
You never have said what size tires you are going to run or how complete a lift you want. Budget? Do you care about on road performance? Off road articulation? You have dozens of lifts to choose from in that size with different components offered.
My personal favs are Mopar, AEV, and OME but that's because my main focuses for a lift are maintaining/improving on-road ride quality, price value in regards to lift component completeness, improvement of off-road capability (flex) and quality of the parts. My target budget was $1K. I don't do rock crawling, mostly snow, sand, fire road deep wood trails, hunting/fishing off road kind of stuff. I'm a 90% on road weekend warrior. If price wasn't a concern, I would also throw in Metalcloak as one of my favs but I also really dislike that gold bling look they put on their parts.
I'm thinking about running maybe 33 to 35 inch tires? Idk, I've been doing some research but according to that the Old Man Emu's are what everyone on the internet are say it's good for overlanding
The one drawback to the AEV kit is that it is an engineered, complete system. It really isn't designed to be upgraded like some of the other brands.
I'll throw out another vote for AEV. Great street manners, flat in the curves and good flex off-road. I've got a 3.5" with 35s, but a 2.5 will be fine for your rig. All of the lifts mentioned here are high quality, but I feel the AEV with the geometry correction brackets probably offers the best "all around" performance. Other lifts may perform better off-road in specific situations, but none of them really out-do it on the street. Now, adding the brackets to other lift kits may produce similar results, though.
Overlanding? Isn't that where you try to drive fast on really bumpy terrains? If that's the case, then that sounds about right because as The Dirtman mentioned previously, OME offers springs with different rates.
no, overloading is loading up with lots of gear and doing long trips to see this beautiful country. Generally need heavier coils to carry all the gear with you.
Thanks Dirtman, then it definitely sounds like he should steer away from TF in addition to the usual concerns of where their stuff is made.
