Recommendations for steering stabilizer clamp/mount for 1.5" tie rod?
Anyone have any recommendations for a steering stabilizer clamp/ mount for a 1.5" tie rod? Just installed Ruffstuff Offset Tie Rod kit and can't re-use the stock steering stabilizer mount. Haven't seen a whole lot of options either.
![](https://staticssl.ibsrv.net/autocomm/Content/JK-Forum/jkamicon.png)
Poly Performance has clamps but you would need to add a tab to mount the SS.
POLY PERFORMANCE OFF-ROAD PARTS :: Fabrication Parts :: Tube Clamps & Flanges :: Synergy Outer Diameter (OD) Tube Clamp
There is also the carolina metal masters clamp, very stout
I just used their steering ram variant for my hydro assist install
Steering Stabilizer Mount | Carolina Metal Masters
I reused the stock bracket with some new 1.5" exhaust clamps. Just dremeled out the stock mounting holes a little, everything else fit perfect. Not as high speed as the aftermarket mounts but a lot cheaper.
Here is the one I have , you have to weld on the bolt yourself
http://mad4wd.com/index.php?main_pag...roducts_id=146
![](http://i257.photobucket.com/albums/hh203/jaknmeoff/20140115_120941_zpsb0ce2596.jpg)
I used one of these from synergy suspension. It's there tie rod clamp and believe its available for a few different diameter tie rods.
Attachment 541910
Attachment 541910
Sent while my wife wasn't looking...
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
![](https://www.jk-forum.com/forums/images/ranks/veteran_air_force.png)
You can also run the SS to the drag link; it will function the same. That's what I did with mine because the slightly oversized TF SS kept getting bunged up when run to the tie rod. I still needed an oversized clamp because my drag link is also oversized, but it came with my Currie rod kit.
![](https://www.jk-forum.com/forums/images/ranks/veteran_navy.png)
Attachment 541910
Attachment 541910
