Recent Alignment...should I be worried?
I hope I'm not reading that as an endorsement for OEM driveshafts over aftermarkets and a proper set-up. LOL. You're really pushing those Rzeppa joints hard--they don't take steep angles very well for very long. Here's some great info on setting pinion angle, and the different types of driveshafts ...
Jeepwire.Com Presents: Setting Your Pinion Angle
Not an endorsement, but you can run the stockers for a long time and they are a lot more forgiving in the situation OP is in. I tore my boot on my first outing after my lift and it survived another 8 trips worth of wheeling and a year of daily driving before I swapped in aftermarket ones. They're not quite as fragile as a lot of people make them out to be.
yea driveshafts are on the ever growing and never ending list of thing i need to buy because i bought something else....i'm going to rock the stockers until they die though
Probably should have gone to the same shop...but i didn't like how they said they changed the camber...since that's impossible.
However...my camber numbers changed a lot...i know that's unrelated to the lift...it's either the machine or MUCH MORE likely...cause I installed a truss.
Should i be worried about that caster....it's barely out of spec.
Everything else looks ok i think(i know the caster got worse...but it drives pretty nice still)
