Rear Track bar mount install question
I currently have the TF rear track bar bracket (frame mount) in place but am going to be switching to the TF axle side track bar bracket as my lift has increased.
Is it necessary to return the frame side of the track bar to its factory location as I move the axle side when I install the axle bracket? Or can I leave the frame side of the TB mounted in its current position?
I am guessing no. TF is closed over the weekend or I'd call them.
Thanks.
Thanks.
Yes, remove one and put the other on. I hope you took heed of what I asked in the other thread Ann's purchased the wrap around style mount instead of the cheap extension.
http://www.extremeterrain.com/terafl...7D&XTID=J13006
Actually you can leave the frame side bracket if you wish. Your goal should be to get the track bar as level as you can while centering your axle. However running the drop bracket will slightly lower your roll center.
I prefer a bracket like this but you have to weld it on.
http://www.ruffstuffspecialties.com/...g/PAN-OFF.html
I know that their frame mounted pivot points are located on opposite sides. Do they work with each other or against each other centering roll?
Or am I just overthinking things now?
It has to do with the way the body rolls on the suspension. The higher the pivot points the less top heavy the jeep feels and yes the front has an affect on it. I don't think the fact the frame mounts are opposite sides has anything to do with the roll center
